G gmangatjr Be Gentle I'm New Here Joined May 29, 2007 Messages 3 Jun 27, 2007 #1 I drive a 98 ford contour se, 4dr 2.0l. I just recently charged the system, and the ac does not turn on. I have a gut feeling that my switch has failed. Where is located???? If there is a high pressure switch where is that located??? Thanke
B BrApple No Life But CEG Moderator Joined Dec 23, 2001 Messages 21,684 Location Gales Ferry, CT Jun 27, 2007 #2 my suggesion is that you need to take the car to a shop and have them check the car over, the charge may not be correct ...
P projectSHO89 Hard-core CEG'er Joined Sep 19, 2002 Messages 1,178 Location St. Louis, MO Jun 27, 2007 #3 BrApple said: my suggesion is that you need to take the car to a shop and have them check the car over, the charge may not be correct ... Click to expand... Indeed, since you can't properly charge the system with a faulty cycling switch which is located on the top of the accumulator. High pressure cutout switch is installed on the high pressure hard line. Steve Last edited: Jun 27, 2007
