Shift Linkage Lock-out
SloTour
95 GL ATX
The lock-out engage for pressing the brake pedal to put the car in drive does not activate the solenoid. I have replaced the solenoid and now today I have replaced both switches at the pedal. I can't seem to get power to the solenoid.
I have it attached to the indicator light, so now I just flip to parking lights to pull outta park then turn them off. :cool:
It's not getting any voltage. What other failure points to the lock-out setup do I need to check?
Your brake lights are probably not working either.
Change Fuse 24 - 15amps - Light Blue - Brake lights.
If the brake lights are working, then the wiring from Fuse 24 to the shift lock-out solenoid is suspect.
