hightower mod
trhlz1222
Holly Springs and Parish
ive been searching about it and find lots of debating. i was wondering if i just sand off the chrome which is better wetsanding or dry sanding. also will leaving it black be fine or does it fade? am i better off getting some kind of black paint for them?
ok. getting the headlights apart will a lil pita. took like 10 minutes of baking for each light to get it then another 10 just to get the grooves cleaned good enough. not as hard as i thought it would be tho.
ended up using chrome polish had some already. turned out great. the lenses are a little cloudy still but alot better then before. wasnt nearly as hard as i thought it would be to do just time consuming
Did you do any sanding on your lenses? I used 600 then 2000 and used 3M Rubbing compoud on a buffer then some plastx and they will shine up as much as you want
Like I said I used the Rubbing Compound after the 2000 and thats what made the biggest difference for me. Since you put clear on them your kinda in a bind because if you do anything now you have to go through that and then get to plastic.
