contour2gq
Doesnt those type of superchargers wear out the front rod bearings unless you make a kit to distribute the extra load from the supercharger belt?
			Don't know what kind of tensioner you are going with but if you haven't already decided you might consider an auto-tensioner. This link shows an MP62 on a Miata with a 6 rib auto-tensioner in action:
http://www.fastforwardsuperchargers.com/videos/AutoTensioner.wmv
Belts tend to stretch a bit under load - you can see the tensioner move a bit to keep the load consistent. Also makes belt changes a snap.
Good luck with the project, should make serious power!
well now you have a reason to.
.................You may also wish to consider that a supercharger ALWAYS places drag on an engine, consuming power, whereas a turbo does not. You also see less of an impact on off boost fuel economy with a turbo, because off boost a turbo is not a being a parasite............
	This is mainly true with cenfrifugal supercharges. Positive displacement untis like this roots stile and the more fefficient twin scews have very little to no parasitic draw when they are at cruising speed.
Wrong, you have it the wrong way around.
Centri's are more efficient. PD and TS are less efficient.
