toursvt
Hope this is not a repost (i did search
 ), but I thought it was pretty cool. Enjoy!
http://www.youtube.com/watch?v=AXVRuN3uqLk&mode=related&search=
Zetec Ftw!!!
The engines used are Mazda derived 2500cc V6 taken from the Ford-USA Probe model. Cosworth Engineering were responsible for the race engine design, selecting the V6 due to it's excellent 24 value twin cam head design and larger piston area compared to the available four cylinder units. The all alloy 60 degree V6 was also light and compact (only 457cms) so could be fitted well down in the chassis to improve the car's center of gravity.
The rules stipulate the use of the standard production block and cylinder heads, but Cosworth replaced virtually every other component within the engine with their own custom built items. An all steel crankshaft and connecting rods were topped with aluminum pistons, the engine capacity being reduced down to 2000cc limit by changing the length of the engine stroke.
I believe most of the BTCC cars were zetec's... since they all say ZETEC on the front where the plates go.
	Well, you guys in the British Isles should know more about it than we Yanks do although wikipedia isn't the be all and end all of dictionaries. I might have even read about the trim level thing on the Mondeo forums. :idea:
Yes, but CEGers that have been around know that he is correct.![]()
Well, it isn't important enough to search for the original post or two that discussed this a few years ago either on this forum, the other Contour forum or the Mondeo forum though I might just to show that no one argued the point at that time. Not even those CEGers who have been "around".Yes, but CEGers that have been around know that he is correct.![]()
