my98SVTturbo
basic question here but did the contours when brand new come with two keys? one for the door and one for the trunk?
Good question. Always wanted to know why my ignition keys don't open ma trunk.
Early idea of a 'valet' key, I assume.
Only give the valet the ignition key and he can't open the trunk or glove box.
Only problem with that is if he is in the car already he can just open the trunk with the trunk release...
unless you flip the switch at the trunk lock ...
There's a switch at the trunk lock???![]()
Yes, right next to where the latch is, there's a hole in the plastic trim. Inside there is a switch, and as it turns out, this activates the trunk lock. This REQUIRES using a key to open the trunk. I have mine engaged, seeing as it keeps my subs safe.
you may think they are safe but you stilk need to unlatch the cord that unlatches the trunk. that is if you hadn't done that yet. then the only way in is the remote.
You people need to read your owners manuals more ...
(if anybody doesn't have theirs: )
http://www.analogstereo.com/ford_contour_owners_manual.htm
the lockout switch DISABLES the side-seat lever that opens the trunk.'
The way in is a key, afterwards..
well the thing is it takes tow ppl to open my trunk. one persons gotta hold the latch up while the other person pulls open the trunck. pretty stupid. whats up with that? im hearing that "the spoiler weighs it down so it wont pop open without help"...but its a factory spoiler...it should open??????
