1995 2L 168,000 miles almost dies after a cold start and has lost its pep. I get 172 EGO lean bank #1, only on tests. I took it by to see if it could be the Catalitic converter. He wasn't sure (with his tests too)but reccommended the fuel filter. I replaced it but did not help. I was told by dealer that the O2 sensor would not make it loose power. There are some spots on the pedal position that at different speeds is better. I (in the past) replaced the sensors: EGR vlv, throttle, egr flow, and fixed the crank sensor wires(bad connectors). The transm has troubles deciding on which gear while you are trying to find good pedal position too. Is it O2 sensor, or cat, or ????
