davygravyt
New CEG'er
- Joined
- May 30, 2007
- Messages
- 8
So I have had a 3l Hybrid swap CSVT for about a year and a half now. A little over a year a go, a piston broke after about owning the car for about 8k miles, and I had a local engine rebuilding shop, Waggamon Brothers rebuild the engine. Since then the car is going through pistons like toilet paper. The shop says it is because the compression ratio is too high. Although 11.25:1 is a pretty high compression ratio, I haven't seen anything on the forums about this being a common problem. Are they right? Do these motors blow through pistons? Or is the shop just not aligning them right or something?
P.S. The shop said there doesn't appear to be any cylinder wall damage.
