Im installing a remote starter/alarm for my 96 mystique. I have done a few in the past, but I need some information first. I just wanted to clear up that I need a immobilzer bypass module for remote start?
Also can someone tell me if this is correct for bypassing the clutch, but still being able to use cruise control?
I used a relay... pin 85 went to the blue wire on my remote start system.. which was a (-)200ma status output... when the remote start engages this wire connects to ground.....
Pin 86 went to (+)12v
Pin 87a normally closed - nothing
Pin 87 normally open - Connected to black/yellow wire coming from pin switch closest to firewall on clutch...
Pin 30 Common - Connected to black wire coming from pin switch closest to firewall on clutch....
Black/yellow and black can go on either pin 30 or 87, as long as they connect when the relay snaps on...
