Help!! Sputtering from idle until the secondaries open up!
Tabari
Hey guys, I just changed my plugs to autolites, wires to taylor, and replaced the valve cover and intake manifold gaskets. Now my SVT sputters from idle all the way up until the secondaries open. Im almost all out of Ideas and was wondering if you guys could help me brainstorm, thanks in advance for the help!
meant to post in here, mods please delete the other post. I triple checked the wires, firing order, and applied the Dielectric grease and it still does it. This is pretty frustrating! please help!
Good Idea I will check that, although it idles ok, there is still a slight miss. Any other suggestions greatly appreciated!
have you verified that the secondaries are working correctly? maybe they are stuck open ...
How do you check this? I understand the secondaries are controlled by the IMRC (under the plastic cover).
I have the same hesitation problem (new plugs/wires didn't fix it).
Ok, so I took the coil pack out and checkd it and it read 14 across 1,4 2,5 and 3,6 and also made sure all of the wires were fine. The car is jacked up right now and im at a loss. The engine got progressively worse and then finally threw a code: P306 misfire in cylinder 6. Re checked the plug wires and coil pack, did th4e dielectric grease and everything seemed fine. Anymore ideas guys? I am going nuts over here
Wow thank you, I just came inside aqnd thats exactly what my dad and I were thinking. On friday we will take the uim off and go from there. I really appreicate the help guys
Good luck. Don't forget to report back and let us know what caused it, for future searches (for those that use the search feature :rolleyes: )
Not aimed at you, Tabari
