Canadian 98 CSVT
Hello all, I'll start with the info...
98.5 CSVT
170,000kms (about 105,000miles)
Just had the dealer do the intake gaskets, also replaced the MAF Sensor with a brand new Cardone unit. The dealer looked at the plugs, appeared to be good in his opinion, and I made sure I had the performance specialist there. (Ford Dealer)
Other recent parts are just brakes and tie rods, nothing engine related.
Before the work on the engine, the car was throwing codes P0171, P0174,
Lean Banks 1 and 2. In a running test performed by the mechanic, O2's were working properly, MAF was weak and introducing gas around the intake pinned the O2's. Hence the intake gaskets were done and the MAF was replaced today. I reset the cpu, cleared the codes and now the CEL is out. I drove it around town, under normal granny acceleration its fine when warm. WOT, it just seems to drag through the rpms. Completely different when cold! Runs like a top, tonnes of power right through the rpm ban. I'm kinda baffled and getting quite frustrated since I've only had the car less than 3 weeks!
I had an 86 5.0 SEFI Mustang that I had running like a top, could always figure it out, but it was speed density, no MAF! (never got around to converting it)
The engine doesn't show its running hot by the gauges, but it has a hot smell when you get out. Can't quite pinpoint it... (not hot oil or coolant)
Shot in the dark, plugged cats? Mind you it just passed emissions testing 3 weeks ago... I'm baffled here, anyone experience this? Maybe know the fix? Plug wires are all original looking to me, but I can't see that being it...
Any other sensors in mind?
Sorry to ramble guys and gals!
:help:
98.5 CSVT
:help:
