		green SVT
Guest
This car is a curse.
Shoulda gotten a Toyota
mmm you better get your flame suit on buddy.
:laugh: Maybe you should.This car is a curse.
that link was very helpful, looks like i'll be getting my engine from here. Once i have the 3l in my possession, and the 2.5L out... how much work is left? Do some parts from the 2.5 need to be transferred and then it's ready to go?
T.O. bearing will squeak when the clutch pedal is depressed due to insufficient lubrication on account of resting foot on clutch pedal or leaving MTX in gear at stop lights, etc. The bearing gets too hot and the lube goes away eventually. It's not unusual for the bearing to require replacing before the clutch but it's easier to replace everything at once if you've got the car torn apart anyway. The bearing only spins when you depress the clutch pedal so it should be silent with MTX in neutral and foot off the pedal.That could be the clutch throwout bearing, since it stops when you push in the clutch. I hope so..
Another CEGer and I just picked this up for $1800. I'll give you the same.
http://www.contour.org/ceg-vb/showthread.php?t=7804
So there's an available 2004 3.0l taurus with 22k on it for under $700. Should i hop on that?
Stazi said:Get a post 2000 motor and save yourself the headaches - plus it'll be in better condition than any older motor. Stay away from the 2004's due to a possible issue with those having trapped zircon from the casting process, still sitting in the block. Zircon = sand = BAD!
