bad idea
buttersSVT
auburn hills, mi
so when i was replacing my struts i figured i would replace te sway bar bushings (link bushings) so i figured i would put poly bushings in, now whun cornering on I75 the rear end of the car tries to get away from me......is there anything better than the stock bushings that i could get that wont be as stiff as the poly bushings, and does anyone else have poly bushings?
Based on both personal experience and the collective knowledge of the org mind, there is no way you can reasonably attribute "the rear end tries to get away from me" to swaybar bushings, alone.
Either something else is jacked up, or there are too many details of your total setup that are left out.
