TRicker
okay here's what i have on my list so far:
2001-2003 Taurus/Sable block (too poor for an escape~!)
SVT cams, Timing equip, valve covers, LIM/UIM, (i have the templates to oval port)
Fluids:
2 gallons antifreeze
1 Quart power-steering fluid
3 quarts ford honey (3.2 is capacity? not sure i just fill to spill)
6 quarts Non-Synthetic oil 5-30 (for break in period)
Oil filter
parts:
Valve cover gaskets (2.5L)
LIM gaskets (2.5L)
UIM gaskets (2.5L)
Oil Pan Gasket (3L)
Clevite 77 rod bearings (standard size)
Rod Bolts (?)
Timing cover gasket (?) ive never had one off, my 2.5L came without one.
Prepping:
install rod bearings, and reinstall oil pan with new gasket (rtv on the corners?)
Remove 3L pilot bushing (i plan to notch it and remove it with a puller)
Install cams (good luck with that i'm told?) timing equipment, and timing cover. install 2.5L pulse wheel. also install 3L valve covers with new gaskets (RTV on the corners?)
tap 3L block (or splice?) for knock sensor.
Remove the tabs on the 3L block (a pic would help plz!)
reinstall the SVT uppers and all that goodness.
oh yeah i should probably remove the old motor before i start to put this one in.....
it feels like im missing a bunch so rant, rave, whatever you do, just help me be fully prepared!
Fluids:
Oil filter
parts:
LIM gaskets (2.5L)
UIM gaskets (2.5L)
Oil Pan Gasket (3L)
Rod Bolts (?)
Prepping:
