I bought a 96 mystique 2 months ago, decided to get it on the road (due to having 2 other cars). I started it up today and there is no cold air. The compressor clutch is not engaging, and the fan does not come on.
Now in my other 2 cars when the key is in the acc position and I turn the a/c on the fans still come on w/o the cars running.
Now I think I know 2 things that are the cause, possibly not enough r134/leak, or clutch is bad/out of adjustment.
Does anyone know a way to jump the low pressure switch to see if the clutch engages? I believe this will tell me wether the r134 is low or not.
I checked in the owners manual, there seem to be no fuses associated with the a/c, only relays. I found a blue relay, somewhat small I believe it was for the clutch engagement, i felt it and it felt fairly warm, is this normal?
