dut to the high pressures involved the whole hose needs to be replaced. I believe that hose goes to the compress and it is also connected to the other hose that comes out of the compressor. Try to pick one up at a salvage yard. Be sure to inspect and replace the o-rings if needed. The A/C system will need to be evacuated and recharged properly once after the hose is replaced.
