Pen_Two
Is not easliy amused.
My guess is it's either the internal voltage regulator or a bad ground.
			Which is why my **** pulsates.
LMFAO! :help: Sounds kinky to me.![]()
what is exactly happening?
I had an issue with a new alternator that when I got above 3k rpm the lights would flicker, as would my voltage gage ... pretty sure the diodes where not working correctly ... in this case the wiring fix will not do anything
I got the Alt tested yesterday, and the Alt is charging the system fine. They Diodes are working fine too. I'm getting surges in the system however which leaves me to believe I have too much resistence in the system. As soon as it has a load, anything above idle, the system surges. All accessories, except the radio, pulsate. I'm going to try the wire fix because it's cheap and easy. I'd rather do the cheap and easy one first instead of the Alt all over again. If this doesn't work, then I'll worry about the Alt.
Oh and I might add that my radio gives me a voltage read out. It jumps around from 13.7 to 15.2. That's the lowest and highest I've watched the guage read. It usually bounces around in the 14's though.
If the mechanic has your car today to do the wire fix he should do some testing. If it is the alternator then he can help you with getting another new one.
Hahaha, I see you quoted me.![]()
