wheel adpaters
carolina brand
Be Gentle I'm New Here
HI I was wonder if there was a car i could us to swipe out parts so i can have 5lug instead of 4Lug. I seen a swipe for a mustang but none for a contour do any of you guys no of a way or should i just buy the wheel adpaters? and if so r they safe
About the only option you have is buying wheels with the correct lug pattern. Running wheel stud adapters requires probably at least an inch for the lug nuts to be recessed. You could do this in the front, but in the rear you'll definetely run into some problems with the offset. Even if you did manage to get this to work, you're going to wear out wheel bearings pretty quickly.
