Reebs
meester super sleuth
Hey guys,
Has anyone installed a Spec Stage 3+ ?!?! I would like to see pics of it, because I think spec sent me either the wrong pressure plate or something is defective with what they sent me. My flywheel has the correct step, and with the pressure plate from my Stage 3+ kit pressed all the way up against the flywheel, I have some serious play with the clutch disc. When the pressure plate is all the way against the flywheel, the clutch disc is supposed to be tight and have pressure on it, but instead I have a 3/8 inch gap and the clutch disc is sloppy as could be. I am not happy right now because I couldn't finish my 3L because of a wrong part. The stage 3+ kit is supposed to have a stage 5 pressure plate, and the pressure plate Spec sent me looks like my stage 2 pressure plate did. Has anyone ever had this problem where the pressure plate can't clamp the clutch disc between the flywheel? I guess the only other option is that the clutch disc isn't as fat as it is supposed to be!?!?
It would really help me out if you guys could post pics of whatever stage clutch you have so that I can try and figure out what pressure plate I have. Am I supposed to call spec or the dealer to try and get this sorted out? Any info would be greatly appreciated.
Thanks,
Jeff
Thanks,
Jeff
