Turbo Project: Progress Post
Status
Not open for further replies.
I remember burrita talking about it in one of his threads saying that it wont be an issue. I'm not sure htough.
yes I asked about that before, since there where holes there already it is kinda a issue, kinda not. but when you think about it the tube will add structure, if you don't cut the hole to large and let it be a snug to tight fit.
Then go to harbor frieght and buy one.
Then step 2 is learn :)
Barge can't weld for **** either but it doesn't stop him from trying
Here we go!!!!!!!!!!!!!!!!
I believe everyone is getting the precision turbo except me. I got the Garrett, and Roberts looks like the precision. By the way Robert, make sure to take that 15 pound spring out of the wastegate before firing her up!!!! :) Your 7.5 should be in your box somewhere! I don't want you to be forced to put the 3L in just yet! :)
Other than that, keep up the good work and keep us updated!
Speaking of not labeling anything ya'll should see warmonger work on a contour. He knows like every bolt size and how many for probably every single thing on a contour. Pretty interesting in person when he says something like there's three 12mm bolts holding that in, 4 13mm bolts holding that, a clip holding that, and your missing a bolt on that.
And my rx7 is apart right now with bolts every where on the floor of the shop. Haven't had a problem yet finding the right bolts, but yet might be the key word.
<--garrett at some point....
What are the turbo specs burt? I see the A/R is 60
Status
