OBD Connector
DarthMuppet
Visalia, CA
Ok, so my check engine light came on. While I am at a stop my RPM's bounce from 400 - 900 sometimes when I first stop but then smooth out. I had a friend with a OBD computer try and hook up to it and pull the codes but it isnt working. Its not able to see the car. I guess its supposed to immediately power up after you enter the VIN into it and start talking to the car and it isnt. Any ideas why that may be happening. I searched old posts and havent found anything like this so I was just wondering if this has happened to anyone.
Does your friend have a ford also? You can have your car off and still plug in. When you turn the car on it should connect. Unless of course his connector isn't PWM compliant.
