Reebs
meester super sleuth
I figured I would post this question in F/I, because you guys are the ones who I need the advice from. I just about to drop in my 3L turbo, and I plan to have between 310hp and 350hp depending on what I set my boost controller to.
I have a stage 2 made of kevlar (not stage 2+) and spec's website says that it is good for 340 ft.lbs/torque. I will be right around maxing that thing out, but I am not sure if they under rate the clutches or whatnot. My spec stage 2 also has around 20,000 miles of moderate n/a driving on it. I know it has life left, but I am afraid to put this beast together and find out that the clutch is slipping under boost.
What clutches are you guys running, and what power do you think/know that your clutch can hold? I know it is just another expense, but I think it would be worth it for me to pick up another clutch. I also don't know what to do about resurfacing, because I have a fidanza LW flywheel.
Well, go ahead and give me some advice!
  My SVT will be driven a ton, so I need a clutch that will have a decent life expectancy.
Thanks,
Jeff
Thanks,
Jeff
