8000RPM
...can someone please explain what happens with the brake fluid once it is poured in the little white tank?? what is right below the tank? is this the master cylinder for the brakes? if so, where is the slave cylinder for the clutch? is it right next to the master cylinder, or is it once piece with the throwout bearing?
when engine is running it is really hard to shift into any gear. engine off...they all feel normal. sometimes when i shift into gear and the clutch is pressed all the way down, there is this grinding noise (like when you shift with a clutch). I just bled the clutch and it should have no air...can the entire clutch be gone?
what are the symptoms of a failing bearing? car is stuck at a friend's house and i don't know if it is a good idea to drive it like that. any help and suggestions are welcome...
