To those running 18's
I put in 5 PSI under tire spec. Right now I run 45 PSI and check it every other weekend. Once it gets around 35 PSI I fill it up to 45 PSI again.
Check out you tire's side wall, it should have its recommend tire pressure somewhere on it.
That is not a recommended pressure. That is the maximum pressure.
Anyways, the 'correct' pressure for aftermarket wheels/tires is gonna be different for everyone on here because of different suspensions, different tires, and different driving styles. Just watch how the tires wear. I see a lotta people run too much air, especially with aftermarket wheels and wear the center tread out quick.
