8000RPM
...well I am intalling them but i have a few questions.
1. the mils. can i do them without the pc board and retminals? i think i can, but i am not sure from the how to, what goes where. I cut the grey wire, and put the resistor between the two ends, right? then the capacitor goes/bridges from the black wire to the gray wire, without cutting the black wire, but just by tapping into it. right? but the other end of the capcitor, the one that goes to the grey wire, where exactly does it go? between the resistor and the 02 sesnor, or the resistor and the wiring harnes plug?
am i missing something?
2. how on the world do you take the egr pipe off. that thing is solid hard stuck and not moving anywhere. any suggestions? I was thinking to unbolt it from the top (where it goes to the egr valve) and take out the rear manifold still attached to the egr pipe...would that work?
