nitrocarmsn
New CEG'er
i have a manual tour and i want to check the fluid in the trans, and i cant find the damn dip stick, i looked for a good 10 min, and i cant see it, where is the thing?
			there should be two "plugs" on the trans. the lower one is the drain plug and the upper one (not much higher) is the fill plug. pull the fill plug while on a level surface and stick your lile finger through the hole to the point that your first knuckle will bend inside the trans. if you feel Trans fluid its fine, if not its low. IIRC its recomended to change it every 60K miles
Happy you dumb beaner?
what the hell is wrong with that statement? How many times have you seen something (espicially with the contour) that isnt there but SHOULD BE?
i mean you SHOULD have been able to power wash your zetec but we all know how that turned out. your fuel rail SHOULDNT have leaked on the 3L but it did.![]()
My god there is a lower bolt and to think I pulled the shaft to drain it. Well that sucks.
