Barge
With all this talk of "boost" and very little talk of CFM I would say that it's a pretty fundamental difference between a centrifigal supercharger and a turbo.
With a turbocharger in a way you are trying to control how much pressure it creates which in tern defines how much cfm the engine will try to use.
With a supercharge you are saying that at this RPM i'm going to spin the supercharger which will produce this much cfm of air. The boost pressure itself is really an aftereffect.
So you're kind of doing the same thing in 2 different ways.
Also note that most turbochargers can build boost pressure (whatever) earlier in the powerband because most of them have turbine much smaller than ideal.. and by ideal I mean making max power at max rpm. Hence the need for a wastegate.
You could make a turbocharger act like a centrifigal supercharger by simply putting on a bigger and bigger hot side until it produced the boost/cfm you are looking for at max rpm w/o diverting any exhaust gas w/ the wastegate.
With a supercharge w/o some crazy gearchanger system or something you have to pick one point where you want the supercharger to excel at because otherwise you have no way of changing the supercharger RPM independent of the engine RPM.
Now if you developed a centrifigal supercharger with a cvd type transmission on it then you could be all sorts of cool. Seems like someone would have done that by now.
I would say that at a singular point in time with the supercharger and turbocharger setup to make max power at the same RPM the supercharger theoretically might actually be better because you would have a much freer flowing exhaust... i guess at that point you'd then have a study of exhaust backpressure vs. mechanical losses.
Just to comment on the bleeding of supercharger boost: You would have to either be using a blow through system or you would have to recirculate that air. The other consideration is that by doing so you are basically making the supercharger work harder for nothing.
