morbid
I've had an issue where the pedal is firm (not overly firm) but the brakes wouldn't stop *that* fast unless I pushed harder on the pedal.  After pushing harder, I can feel the pedal give a little then it starts to brake more.  If I get on the brakes hard... the pedal gives a couple times, but it won't slow fast enough to engage the ABS.
At that point... my rotors and pads were in bad shape, so I replaced the fronts with the 13" Baer kit. The problem was still there, but less (bigger brakes). So I moved to the rear and installed the TCE 11.75" kit. The problem is still there.
I've bled the fluid several times... and both front and rear pads are properly bedded.
Now when I replaced the rotors, the rears appeared to be more worn than the fronts, which I was hoping happened because I had too aggressive pads on the rear. Does the above sound like something might be affecting my bias, or does anyone have any ideas?
The rear caliper is the only component after the hard lines that hasn't been replaced. Could they be the problem? Maybe an ABS component? Also I have never bled the master (don't think it's ever gone dry) and also have never actuated the ABS while bleeding (though previously I have actuated it many times on the street).
I'd greatly appreciate any input... thanks!
