Headlight Refurb?
flcontour98
New CEG'er
central florida
My headlight lenses have finally began to fade and yellow. I've seen the price of replacements, and it is currently not an option. What can I do to "gussy" them up?
Thanks in advance for your responses!
For starters, try some Plastic Polish and a PowerBall Mini. If that doesn't cut it, try some Mag Polish... then resort to sanding.
I wetsanded (1000/ 2000 grit + soapy water) mine, and it really took out the yellowing. They are still hazed, but I believe the polish is supposed to take that out.
Wet sand from 800 to 2000 using the 1000, 1500 inbetween. Then use a cleaner wax to pick up the inperfections. After that you'll want to use a plastic POLISH, then seal it with wax. It should look new, or newer especially at night.
