jca1980
CEL CODES:
0171: System to lean bank 1
0174: System to lean bank 2
1131: Lack of upstream heated oxygen sensor switch. Sensor indicates lean bank 1
1151: Lack of upstream heated oxygen sensor switch. Sensor indicates lean bank 2
HISTORY:
For a long time Bank 1 was acting up causing the CEL to come on. But the car ran "OK"
At some point in the fall Bank 2 joined the party.
SYMPTOMS:
Really bad fuel efficiency. (approx 350km/tank)
Loss HP/Torque (really noticed in the hills)
Occasional drop in idle.
Very occasional stall.
PREFORMED MAINTENANCE:
Replaced the fuel filter in the fall.
Vacuum tested ERG valve in the fall. (Passed test)
From what I have read in the forums its is likely a Vacuum Leak.
I'm gonna go pick up some cleaner and see if I find a leak. Though at this point I'm not sure where I should start looking for the Leak. On the passenger side of the engine bay I can hear what I think sounds like air flow (near the belt so its hard to be certain).
Also I have picked up two O2 sensors (Bosch pt#13115)
Any pointers or help is very much appreciated.
I am aware of the BANK 1 O2 "How To".
Thanks Guys (and Gals?)
HISTORY:
SYMPTOMS:
