tension on pedal
qokuh
New CEG'er
I was wondering if there is a way to put some more resistance on the gas pedal. When I hit some bumps at low speeds it is very touchy(1st gear).
maybe you could change the spring on the Throttle Body. But, I don't know of anyone that has changed their spring or of anyone making a stiffer spring.
All of the resistance really is at the Throttle Body, so if you want I bet you could have a shop custom fabricate a spring for the throttle body plate that is stiffer then the stock one.
