lovemycountour
Be Gentle I'm New Here
- Joined
 - Feb 7, 2007
- Messages
 - 3
Hi,
I'd first like to thank all of you who've helped me with my car. This forum has answered a lot of my questions - even though I just finally got around to joining. This is going to be long. but feel free to skip to the end if you're just interested in the question...
My Contour is a 99 SE, 2.0 Zetec w/ 5-speed. It's utterly stock, and has been the most reliable car that I've ever owned. It has 186K on it, and has had only routine maintenance on it during that time - with the exception of an alternator replacement at 85K. The engine had been running flawlessly until after I recently replaced the timing belt.
I purchased the requisite "timing kit", consisting of the flat metal plate to align the camshafts and threaded to align the crank. I followed the "revised procedure" that Ford put out in theirTSB.
The process was pretty routine - aside from some major grief getting the bolt on the harmonic balancer to come loose. When I put the engine back together again, though, it would not start. It acted as if it was getting little if any compression.
I checked the compression (not very precisely) and found roughly the following:
1 - 100 psi
2 - Neglegible
3 - Neglegible
4 - 150 PSI
This just about *had* to be a valve problem, so I took everything apart again and I went through the process one more time - trying to be extra careful. This time, I checked the compression *before* I put everything back together. The results were pretty much the same as before,
By now I was really scratching my head. With the special tools, there really didn't seem to be much of any way that I could set it up wrong. After all, putting the pin/plate in place were supposed to guaranty that I had everything set up correctly. The only way that it could get messed up was if that assumption was wrong.
I had been relying on the combination of the mark on the harmonic balancer and the insertion of the pin to know that I had the engine at TDC on #1. To check this, i used the old trick of sticking something in the spark plug hole on #1 and visually checking when it got to the highest point.
What I found was that TDC was *not* where I had thought it was! I put the pin into the side of the block, and it went in just fine here as well.
What I learned was this:
1) There was more than one mark for aligning the harmonic balancer. The on that I used was *not* the one that I should have used.
2) Contrary to what the instructions imply, the alignment pin will fully insert in locations *other* than a TDC! It works as a "stop" at the correct location, i.e. you can't get the engine to turn any further than TDC, but you *CAN* fully insert the pin quite a bit further back than that. A FULLY INSERTED PIN DOES NOT GUARANTY THAT YOU'RE AT TDC!
I seem to have set up the engine with the crank roughly about 7 degrees before TDC on the previous attempts. I suspect that I may have bent the valves on at least cylinders 2 and 3 while set up that way, but there was no noise, etc. to indicate that this might have happened.
Has anyone had bent valves on a Zetec? It's supposed to be an interference engine, but I've read a number of accounts of people fixing engines after a timing belt/idler failure on these. None of these mentioned valve damage, so I'm a bit puzzled.
I'd love to hear from anyone who can give me alternate explanation for what I'm seeing, but bent valves is my best guess at this point.
Thanks.
1 - 100 psi
2 - Neglegible
3 - Neglegible
4 - 150 PSI
Thanks.
