stalkersvt
- Joined
 - Jun 29, 2004
- Messages
 - 52
My contour has a little under 72k on it. So far i have had to do the following maintence and repairs.
Running Mobil1 extended life, have 14k on it, and hasnt burned any oil yet.
Crackshaft sensor: the pins in the connector got wallered out and i had to tighten them with a some plyers at the connector. (this is a horrible problem, as it will intermitently run)
Fuel filter x2, goes bad fast. 60k and 70k
replaced belts at 70k
Replace batery 2 times. When these go you the car acts like a demon is in it. The tack, trip and odomerter went to max, and the car was at idel in the burker king drive through.
cleaned the IAC to de moose every 3 months.
Other than that, no major problems, the synthetic is much cleaner that the old oil i used even after 12k, old 3k oil was black.
Check engine light has been on for 3 years, the o2 sensors are shot, and i replaced them went bad 3 months later. runs fine might make me some MIL elimators.
Update:
75k Needed new passenger window regulator and motor.
Update:
