Rust on rims
rjrosenow
I had a seized caliper throw a bunch of rust and brake dust on my rims. It's caked on there pretty good. Is there a safe way to remove it without damaging the clear coat? I've tried brake parts cleaner but to minimal effect.
Thanks.
I used some goo gone gel to get most of it off of mine, most of it came off with light scrubbing using a wheel brush. What was left I used the Eagle One chrome polish that comes in the metal can,that took off all the caked on hard to remove areas.
A good spray-on, hose-off wheel cleaner like Eagle1 AtoZ All Wheel and Tire Cleaner would be a good idea. Use as directed and agitate with a soft brush and rinse well.
Then you can use an old clay bar to pull anything that's stuck or embedded.
