CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by TourDeForce: Originally posted by Big Jim: I just realized that I should mention that there are different part numbers on the restrictors if the car has ABS, so use ABS restrictors on a car with ABS and non ABS restrictors if the car is not equipped with ABS. They look just about the same.
This thread is for replacing drums with discs. Did any drum brake equipped cars come with ABS?
Mine did.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 63 |
Originally posted by LoCoZ: Originally posted by TourDeForce: Originally posted by Big Jim: I just realized that I should mention that there are different part numbers on the restrictors if the car has ABS, so use ABS restrictors on a car with ABS and non ABS restrictors if the car is not equipped with ABS. They look just about the same.
Mine did.
'00 tour with rear drums and abs here
CEG road warrior
CEG road warrior
Posts: 17,248 |
Just did the drum to disc conversion with SS lines.....time to break these bad boys in!
Hector
257HP/259TQ
160HP/141TQ
Posts: 219 |
Is there an issue with getting the parts from the Cougar's if your going to keep the stock 8 spoke 15"ers? Since the Cougars that came with rear discs have 16"ers.
Posts: 1,145 |
nope the cougar's disc brake setup is the same as the ones on contour's and they have 15's so you are pretty safe.
anyone correct me if im wrong
98.5 Black SE ATX
Posts: 3,887 |
4 wheel disc V6 cougars are the same as 98.5+ SVTs Early SVTs had slightly bigger calipers different pads and caliper brackets. 98.5 SVTs had the smaller calipers and the offset caliper bracket to make them fit over the bigger rotors. The big difference is the caliper bracket. ON 98.5 SVTs and the V6 4 wheel disc cougars they used a cheaper smaller caliper and made an offset bracket to make it clear the rotor. Contours and Cougars use the same calipers, brackets,and rotors in the rear.... For those equipped with disc brakes that is. Half of my SVT has Cougar brake and suspension parts on it.
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
Posts: 610 |
could i do it on my I-4 tour? would the cougar knuckles fit?
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ContourGuy9817: could i do it on my I-4 tour? would the cougar knuckles fit?
I did it....
Hector
257HP/259TQ
160HP/141TQ
Posts: 3,732 |
i got all the aprts needed for the conversion that id be willing to sell...
Russell
Oval Port 3L Nearly Done
Posts: 2,086 |
Originally posted by LoCoZs/c: Originally posted by TourDeForce: Originally posted by Big Jim: I just realized that I should mention that there are different part numbers on the restrictors if the car has ABS, so use ABS restrictors on a car with ABS and non ABS restrictors if the car is not equipped with ABS. They look just about the same.
Mine did.
My 97 Mystique GS has rear drums with ABS. and Russell how much are you selling those parts for and they will fit on stocks right? I'm on a tight budget must not think about mods ugh ![](/ubbthreads/images/graemlins/nonono.gif) ------------------------ 1997 Mercury Mystique GS ZETEC almost 70K and going strong, needs paint work.
Jason G.
Born: 11/96
