Posts: 1,756 |
I'd appreciate any help here. Just add what you think is a common question. I'll start with the easiest ![](/ubbthreads/images/graemlins/grin.gif) .
Our bolt pattern is 4 x 108.
Posts: 3,867 |
Stock offset (49.5mm, IIRC)
Acceptable offsets for aftermarket wheels...(38-43?)
Recommended tire specs for various rim diameters...
Stock wheel weights (approx.)
Early SE 7-spoke: 19 lbs
E0 SVT (Cosworth): 20.5
E1 SVT (Cobra): 19.5
Function before fashion.
'96 Contour SE
Posts: 3,632 |
What other cars use 4x108 pattern?
"Cobb - It's not just for corn anymore!"
Posts: 2,353 |
Originally posted by MotorCity: What other cars use 4x108 pattern?
Old Audi's and Ford Focus's. That's all I know of.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 3,632 |
Originally posted by path914: Originally posted by MotorCity: What other cars use 4x108 pattern?
Lol. I was just putting out a question for the FAQ.
I think the newest Cougars had the same pattern as well.
Posts: 3,867 |
Early SE 7-spoke: 19 lbs E0 SVT (Cosworth): 20.5 E1 SVT (Cobra): 19.5
Correction/addition:
Stock offset for the early 7-spokes is 47.5mm (as stamped on the back.)
'96 Contour SE
Posts: 661 |
How about:
- Will 225/50 fit stock rims without rubbing (YES!) - Does 225/50 throw off the speedo noticeably (NO!) - What are popular upgrade sizes for stock rims because 215/50 is so hard to find (205/55, 225/50, 225/45) - What are some of the popular replacement tires at each price point? - If I replace my KDWs with all-season tires, will I notice the difference? (YES!)
99 SVT Contour Silver Frost, #365/2760, DMD
98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD!
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
Posts: 2,517 |
Benefits (if any) of running 7.5" vs. 7" on 17's, 18's so on and different offsets the different width wheels that should be run.
Thought that might want to be addressed as well...
Posts: 1 |
What is the stock rim diameter for available year & package (GL/LX/SE/SVT)?
