Posts: 218 |
Just to let people know what I just went through. I had grinding going into 3rd so I figured since I'm going to have to pull the tranny out myself that I would try ang get everything needed to tackle this task so that I wouldn't have to do this again anytime soon and get all the parts up front. Just so you know if you have the same 3rd gear problem I did you will NEED to replace the brass parts since that they are the #1 wear items for this problem, next the obvious is replace sychros. That is not all to my surprise the 3rd gear out of my 2000 is out dated and Ford has a revised and I was not able to match the new parts w/ my factory 3rd gear I was told that Ford NO longer makes the parts that would work w/ my 3rd gear out of my tranny and the associated new parts like the brass teeth and sychros. So after going back and forth w/ Ford and the machine/tranny shop I was getting a little iritated knowing that my car was on jack stands @ my house and all I wanted was the right parts to get my car back on the road again. SO if you are planning to tackle this task yourself you will need a machine press to get the outer bearing off the shaft and that it should be replaced F8RZ7025BA I believe (Ford CD says Not reusable) You will need updated 3rd gear w/ (2) YM2Z7107EB Brass rings (1) F*RZ7124BA Synchronizer Assembly. Good Luck and thanks for reading my experience and hopefully others will learn from it.
Posts: 256 |
Ok a few more dumb questions.. My trans feels rough from 3rd to 4th on cold days only. BUt..since im going to drop the trans for a clutch replacement I thought I update it. From the research i just did these are the numers I came up with:
1-2 shifter fork $19.43 3-4 Shifter fork $22.45
Syncro 3-4 $35.89 Syncro Cone $40.05 Syncro blocking ring-3rd inner and outer, 4th & 5th $47.71
Oil seals $26.49
About $193.14 to update tranny Is there anything i'm missing here?
Then im looking at the shift tower update for around $212.55 What this do?
I want to make sure I have all the stuff here when im ready to do the clutch.
Posts: 137 |
I recently got quotes and bought some parts.
Here is the quote that I got
1-2 Shift Fork YS2Z-7230-BA $22.63 3-4 Shift Fork YS4Z-7230-AD $22.45 5-R Shift Fork XS8Z-7230-DD $22.69 Syncronizer Blocking Ring (1st & 2nd; Outer) F5RZ-7107-B $20.81 Syncronizer Blocking Ring (1st & 2nd; Inner) YS4Z-7107-DA $19.24 Syncronizer Blocking Ring (3rd Inner) F5RZ-7107-DA Syncronizer Blocking Ring (3rd Outer) F5RZ-7107-A $28.03 Syncronizer Blocking Ring (4th & 5th) YM2Z-7107-EB $10.30 Syncronizer Blocking Ring (Reverse) YS4Z-7107-GA $19.24 1-2 Syncronizer F8RZ-7124-AA $90.22 3-4 Syncronizer F8RZ-7124-BA $36.51 5-R Syncronizer 97ZZ-7124-CB $63.95 Syncronizer Cone (3-4 related) F8RZ-7M000-BB $40.05 1st Gear (Needle Bearing) F5RZ-7K274-A $12.20 2nd Gear (Bearing) F5RZ-7K169-A $35.27 4th Gear (Needle Bearing) F5RZ-7K171-A $9.62 5th Gear (Needle Bearing) F5RZ-7K275-A $7.39 Reverse Gear (Bearing) F5RZ-7M037-A $20.77 Input Front (Bearing) F5RZ-7025-A $19.81 Input Rear (Bearing) F8RZ-7025-BA $21.41 Output Front (Grooved Bearing) F8RZ-7F431-BB $15.15 Output Rear (Ungrooved Bearing) F8RZ-7F431-AA $14.61 Oil Seal (Input) F5RZ-7048-AA $7.42 Oil Seal (Output) F5RZ-1S177-AA $6.79 Transmission Sealer (maybe not correct) 19B508 (TA-14) $19.13 Redline MTL 75W/80W 50204 $7.95
In that list there are 4 bearings that I did not find anywhere else in this thread. The bearings are the input and output shaft bearings: F5RZ-7025-A, F8RZ-7025-BA, F8RZ-7F431-BB and F8RZ-7F431-AA. It would be cool if they were added to the excel spreadsheet.
1998 Contour SVT Black w/ Blue interior
Torsen LSD updated shiftforks
Lightened Flywheel, HD Drivelines
Optimized Thottle Body
2003 3.0L engine upgrade (Soon to be)
Posts: 124 |
i have a question is there a part number for the mtx-75 tranny mount?
2000 mercury cougar V6 5spd
3.0L SVT mated to my HMS tranny......
a wolf in sheeps clothing
Posts: 291 |
I tore my 95 trans apart last weekend. Although the assembly date of the car was 2/95, many parts are build dated in 94 or 1/95. I used the updated shifter forks and each 1 was different from the stock parts. There were NO ball bearing type bearings on any of the existing shift forks. All were a babbet type bearing. Also, there was no splash shield on the 2-3 fork.
The how-to posted here was OK, but there are a no. of differences with the rod actuated trans. I did not upgrade the shifter tower although I believe it could work. Getting the new forks in the case correctly was a bit tricky. The shafts were in fabulous shape considering the transaxle has over 155,000 miles on it.
Trans is not in the car yet so I cannot comment on improved shift feel. Anyone with an early, wishing to do this job can PM me for help or info., if so desired.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
Posts: 21,197 |
Originally posted by Bradness: All were a babbet type bearing. Also, there was no splash shield on the 2-3 fork.
The two forks are 1st/2nd, VERY early had b/bearings
now the Focus 1st/2nd has them, other is 3rd/4th with
revised splash shield...Read the damm CD, does have pictures!!!
Wrong fork....3rd/4th fork has the splash shield..
...rod shift will not accept a cable shift tower!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 291 |
"The two forks are 1st/2nd, VERY early had b/bearings now the Focus 1st/2nd has them, other is 3rd/4th with revised splash shield...Read the damm CD, does have pictures!!!"
Hey I wasn't sure which was which, didn't check the p/n's on the box, I was just getting in and out, doing the damn job. I used Tom's description of which fork had the splash shield on it so get on him, not me!
What CD are you referring to? My 95 Ford manual is a HARD COPY (if that's what you're talking about). When you're on dial up, pictures are a luxury I don't have (unless I want to wait & wait & wait). Understand now?
Posts: 5,810 |
Don't defend yourself! You posted what you could and if a correction is needed to be made then that's okay too. Although a little politeness should be in order I'd think! It's been so long I could have made a mistake on the numbering, but it wasn't meant to be the end-all of transmission repairs. It was meant to take out the mystery of doing light work to these transmissions so that others could benefit. Someone is riding this forum like a friggin harpy so you should expect that any post on here will take flak.
See My Mods
Posts: 122 |
Does anyone have some pictures of the syncro parts? I just picked up a used trans and tore it apart to upgrade it and was wondering if someone could help me to determine if the syncros were still good or should I replace them. I've got pictures but seeing as I'm still kinda new here I'm not sure how to post pics yet. I know it need the fork and tower upgrade, but there's no point if it's got bad syncros and I can't tell by looking. I don't see any wear or ground metal, should I go by feel?
Any help would be appreciated.
For Sale 98+ SVT gauge cluster
'98 Mystique LS
2.5l 5spd
Posts: 21,653 |
Originally posted by warmonger:
1-2 Fork: XS8Z 7230 DD $18.28 3-4 Fork: YS4Z 7230 AD $24.98 5-R Fork: YS2Z 7230 BA $17.57
Using teamfordparts.com it shows the 5-R shift fork being what you listed as the 1-2 fork and vice versa. What is correct?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
