Posts: 1,238 |
What about using the FSVT master cylinder? Would that help with the distribution? I havent seen a FSVT MC so Im just spitballing. ![](/ubbthreads/images/graemlins/laugh.gif) -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 337 |
Nope. The Focus MC is smaller.
And changing the MC won't change the bias. *at least not static.
Being smaller it will provide more pressure for the given leg. That's going to mean two things; longer pedal (probably bottomed with massive rear calipers) and increased pressure which will only go to activate a prop valve sooner, thus cutting rear pressure sooner.
If you were to run all that caliper piston area I'd say do a 1.062 or 1.125" mc. Lower out put per leg, firmer feel, and ample volume.
*what I find interesting is that in the 12 years I've been playing with this stuff I see the factory changing how they do things too. Used to be that most of the car had large piston areas and larger bore MCs than I'm seeing on current cars. They have opted for larger rotors- from about 10" to a more common 11.5 as a rough guess. This nets the same things we in the biz offer but on a more tame level. The single pot on the Impala SS is huge, the SHO quite large, the Contour stil much bigger than say that found on the SRT4 or the small parts on the MINI. The current design seems to favor more rotor, less pistona and elevated line pressures. Can you guys comment?
Posts: 5,810 |
Wow. This is so informative. So what happens when you raise the front piston and rotor size but keep the same rear piston size using bigger rotors. In effect, you change piston size on your front kits and use the stock rear caliper with bigger rotors. I guess what i'm asking is this: If you don't change the rear piston size and pad type then what good is the larger rear rotor and how does it throw off the bias with larger fronts? With stock fronts?
See My Mods
Posts: 337 |
Originally posted by warmonger: Wow. This is so informative. So what happens when you raise the front piston and rotor size
The front bias % goes up.
The rear bias % goes up.
Depending upon the numbers you end up right back to the same basic % the factory started with- or very near it.
It adds leverage in simple effect, adds more thermal capacity, balances out the front kit, and looks better.
It doesn't.
With stock fronts?
It could have a bad effect.
Posts: 5,810 |
Ok, this is what I got out of that: - raising the fronts with the FSVT kit will increase the front bias which isn't dangerous at all. - raising the rear bias without touching the fronts is bad, and is accomplished by pad or piston change. Rotor affects it less.
- raising the front bias and increasing just the rotor diameter on the rears with everything else the same seems to be ok.
See My Mods
Posts: 456 |
Hey, when are these brackets coming to a CEG'er "near me"?
i want wit 300mm rotors...............
01 PORSCHE 996 ![](/ubbthreads/images/graemlins/smile.gif)
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
96 GL MTX Zetec 2.0 ![](/ubbthreads/images/graemlins/smile.gif)
White/Blue
Blaupunkdt Houston
K & N Drop in/Koni Kit
18"RageEnduros/Flowmaster 40 Series
