Originally posted by TheGreatOne:
I need to wire up the HVAC indiglo's. I'm looking for something preferrably that's on with the headlights. TIA
:DBecause mine match perfectly. There is a switch on them to switch from Green to Blue.... I probably sound pretty stupid because you already know about that I'm sure. Just Pull the insulation back a little on the White w/ Orange Stripe wire on back of dimmer switch and you can control the HVAC Indiglo By the Dimmer Switch Hope This helps... Good luck....
P.S. They Should be the same color....
![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif)
