Posts: 644 |
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 2,807 |
I did this myself about 1 month ago and I couldn't agree more. This mod should help cold weather shifting, we shall see this winter.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 38 |
Hi, could you please tell me where I could find the "recipe" for the tranny cocktail? Is the fluid change same as in the manual(drain fluid, fill with four quarts, run till hot, drain fluid & refill with four more quarts) or more invovled and replacing all of the fluid? Re. replacing all of the fluid, could you disconnect a line from the tranny cooler and blow out all fluid with compressed air? Maybe messy, would it cause any problems filling up, like air lock? Look forward to your response,
Cheers.
David BC
White '96 Mystique GS ATX
HM Intake-K&N
Knauberised
Flo-Pro Muffler (No Res)
Kenwood KDX322
1600W MA 6 channel amp
2x 12" MTX Subs (in a box)
4x SPS570 Alpine door speakers
Viper alarm/starter
Posts: 2,166 |
Should everyone do the Ford FM cocktail?
I thought I remembered an old post advising not to do it if you don't think you need it.
Anyone else know about this?
Thanks,
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 857 |
Originally posted by DavidBC: Hi, could you please tell me where I could find the "recipe" for the tranny cocktail? Is the fluid change same as in the manual(drain fluid, fill with four quarts, run till hot, drain fluid & refill with four more quarts) or more invovled and replacing all of the fluid?
Cheers.
The tranny cocktail is only for manual transmissions, not automatics. As for changing the fluid in the automatic, would not recommend compressed air as it will probably not do much except make a big mess.
Posts: 305 |
Originally posted by louisw: Originally posted by DavidBC: Hi, could you please tell me where I could find the "recipe" for the tranny cocktail? Is the fluid change same as in the manual(drain fluid, fill with four quarts, run till hot, drain fluid & refill with four more quarts) or more invovled and replacing all of the fluid? Re. replacing all of the fluid, could you disconnect a line from the tranny cooler and blow out all fluid with compressed air? Maybe messy, would it cause any problems filling up, like air lock? Look forward to your response, Cheers.
If anyone can post or point out where this "tranny cocktail" is I would like to give it a whirl. I have issues with my syncros so anything I can do to try to help my tranny is worthwhile to me.
Posts: 857 |
3 qts synthetic ATF + 2 oz Ford friction modifier. part number is in the FAQ. I remember that some of the newer transmission have a capacity of only 1.8 qts, not sure if a proportioned mix would yield the same results.
Posts: 21,653 |
David,, there is a way to remove a line from tranny cooler put it in a bucket, then turn car on while pouring new fluid in. fill bucket to max of what the tranny can hold and then a little more to clean it out. Reconnect line and top off.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,693 |
Originally posted by Kremithefrog: David,, there is a way to remove a line from tranny cooler put it in a bucket, then turn car on while pouring new fluid in. fill bucket to max of what the tranny can hold and then a little more to clean it out. Reconnect line and top off.
As others have mentioned, the tranny cocktail is only for manual transmissions.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,831 |
Cheers.
Right here: Cocktail recipe
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
