Posts: 115 |
I posted a while ago about replacement bearings from McMaster-Carr. The bearings are the same size, shape and type as the GC bearings, BUT they are rated for much higher loads. Now I have had theses bearings on my car since X-Mas time, and have driven around about 40% of the time SLAMMED... on Michigan roads. I checked the bearings last weekend, NO PROBLEMS.
Of course though when I told everyone about these bearings, I was given the usual CEG slam, because they weren't over-engineered. Well maybe theses same members who slammed me are now questioning themselves.
In any case, the bearings i found will cost you about 10$ including shipping for both fronts, and this includes everything you need.
If you want more info, email me at emailpierre@email.com
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 433 |
Originally posted by PuckPuck: I posted a while ago about replacement bearings from McMaster-Carr. The bearings are the same size, shape and type as the GC bearings, BUT they are rated for much higher loads. Now I have had theses bearings on my car since X-Mas time, and have driven around about 40% of the time SLAMMED... on Michigan roads. I checked the bearings last weekend, NO PROBLEMS.
If you want more info, email me at emailpierre@email.com I'm interested...waiting for the other one's seems to be a big waste of time. ![mad mad](/ubbthreads/images/graemlins/default/mad.gif)
Silver Frost 2000 SVT #1443 of 2150 Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals Ventshield raingaurds, moonroof and hood bug deflectors True Rev Induction Kit/ BAT Air Inlet Pipe Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62. Motorola Timeport HF car kit Looking to increase performance! http://photos.yahoo.com/hpick1 Future Mods waiting to be put on: Lotek Guage Pod w/ volt, a/f ratio, and oil pressue. Blue neon undercar kit Aussie Bar w/ upgraded backing plate Bullitt Fuel Door Magnacore Wires Ground Control Kit w/ Koni Struts
Posts: 115 |
http://www.mcmaster-carr.com Part #s 5909K35 - (you need 2) theses are the bearings 5909K48 - (you need 4) theses are the washers they install the same way the ground control bearings do SIDE NOTE: I told someone else via email a bad part number - i told you one size lower by accident (long story on why)... anyhow get theses ones, they are only about 7$ shipped to your door
Posts: 1,627 |
Order the Mcmaster-Carr bearings, they work excellent.
00 Black SVT #1545 Ground Control. Koni. 18" Konig Tantrum. More.
Posts: 5,805 |
This may help...apart from the uprated bearings you may also want to add bearings under the top spring set to aid turning effort and increase the bearing contact area."Strange Engineering' have bearings with a 2.5" ID that can be used,not a sealed bearing but bigger than the GC bearing.Strange Engineering bearings can be found on the chassisengineering.com site, the part # for a pair is #1001...it may help.. ![wink wink](/ubbthreads/images/graemlins/default/wink.gif)
Posts: 2,481 |
Jack up the car, grease the bearings every couple months. Should be fine. I use to do this to my car, but after awhile of driving around on Michigan streets, they will need to be replaced. I posted a while ago about replacement bearings from McMaster-Carr. The bearings are the same size, shape and type as the GC bearings, BUT they are rated for much higher loads. Now I have had theses bearings on my car since X-Mas time, and have driven around about 40% of the time SLAMMED... on Michigan roads. I checked the bearings last weekend, NO PROBLEMS.
In any case, the bearings i found will cost you about 10$ including shipping for both fronts, and this includes everything you need. I also posted the same info about a year ago. I think this is where some of the Canadian guys made their money. :rolleyes:
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 3,223 |
Originally posted by Terry Haines: This may help...apart from the uprated bearings you may also want to add bearings under the top spring set to aid turning effort and increase the bearing contact area."Strange Engineering' have bearings with a 2.5" ID that can be used,not a sealed bearing but bigger than the GC bearing.Strange Engineering bearings can be found on the chassisengineering.com site, the part # for a pair is #1001...it may help.. Terry, I couldn't find them on the site, I'll keep looking, could you explain what you mean by putting one "under the top springset"! Thanks, -Andy
Posts: 5,805 |
Sorry,typo'...springSEAT....between the spring & the alloy cap/seat.....
Posts: 5,805 |
Any, call them @ 561-863-2188 for tech info,the bearings are in the 2002 catalog, page 17, 'Coilovers & Shocks'... ![wink wink](/ubbthreads/images/graemlins/default/wink.gif)
