#314520 07/01/02 02:29 AM
E
E
Both my cams are now where they should be! I am so happy. smile It also let me do a quick inspection on my timing belt tensioner, everything is fine there. smile
The car is so quiet when its idling now, it sounds completely different. I need to disconnect the battery and get the so it can relearn everything the way it should be. There isn't a whole hell of a lot of resistance on the cams when the timing belt is off.
Sadly though, I couldn't find the part for my oil leak. The guy at Auto Zone says that the seal I need is probably part of an oil pan set. [sarcasm] yippee! [/sarcasm]
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#314521 07/01/02 02:29 AM
E
E
BTW, Scot, did those instructions I gave you (while you were eatin) work for you?
· Jon Miconi
#314522 07/01/02 03:31 AM
H
H
yes-
I just need to get my account # I dont remember the routing # either- but soon enough!!
'98 SVT #2253
Currently DEAD!
Cobra Paradise
#314523 07/01/02 04:42 AM
E
E
If you have a check you have everything you need. Its those funky numbers on the bottom. smile
· Jon Miconi
#314524 07/01/02 03:42 PM
That's good to hear. laugh
-Colter
My Car
Moderated by  Keyser Soze
