Both my cams are now where they should be! I am so happy.
It also let me do a quick inspection on my timing belt tensioner, everything is fine there.
The car is so quiet when its idling now, it sounds completely different. I need to disconnect the battery and get the so it can relearn everything the way it should be. There isn't a whole hell of a lot of resistance on the cams when the timing belt is off.
Sadly though, I couldn't find the part for my oil leak. The guy at Auto Zone says that the seal I need is probably part of an oil pan set. [sarcasm] yippee! [/sarcasm]
