Posts: 1,119 |
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 2,097 |
If that is driver's side...I have an extra brand new GCK axle...I'd sell it to you.
98 E0 SVT with some stuff
Posts: 1,119 |
Its the passenger. How can you fix this?
In the "how-to" it says it will just push back in. And I found another post that said the same thing. But I really don't see how it just pushes back in.
I need to see if I can find an internal Diagram so I actually know what I am "pushing" back in. That might help alot.
Trubendz Exhaust
Custom Hood
Posts: 5,345 |
Should have bought the $20 ball joint/tie rod removal too1 (the one that almost everyone says is not needed).
Tie rod/ball joint removal tool
The axle end is like a spline. Just turn it a little bit if it doesn't go in the first time you push it in.
Some pictures from Autozone
1996 V6 ATX 96K miles
Posts: 1,119 |
god damn it I KNEW there had to be an easier way. Last night I was sitting there say WTF because the whole ordeal yesterday was really unsafe. I'll have to take my mom's blazer down to advanced when she gets home and I'll pick one up for the other side. But hey while we're on the subject of tools that make life easier, is there one for the CV joints?
Trubendz Exhaust
Custom Hood
Posts: 5,345 |
To separate it, from link previously posted.
"Separate the outer CV-joint and halfshaft from the wheel hub using Front Hub Remover/Replacer T81P-1104-C and its associated components, or equivalent."
Posts: 1,119 |
exactly I don't want to take any more parts off the car. So a hub seperator will only get me farther along taking the entire car apart. Or is it impossible to just "push" the inner cv joint back in without removing the outer hub?
Trubendz Exhaust
Custom Hood
Posts: 5,345 |
Yes, it is possible and it has been done before.
Some good reading info from this thread.
Posts: 21,197 |
Someone didn't read up on old posts. Made your life very difficult.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,119 |
No I printed the how to and I did search. Not alot comes up for inner CV joints. And searching for the removing the LCA game me alot of the posts saying the LCA comes off real easy.
But all of this maybe have something to do with the fact that the springs that came off my car are 18 inches long. Is that normal height of the stockers? It seems ungodly huge and I had alternate spring comrpessors to get it off.
Trubendz Exhaust
Custom Hood
