Posts: 191 |
It feels as if my rear spring is broken. i can hear it. how much do these go for? do i need to replace both? also i read up the faq and it doesnt look to bad to change. any done this before? how was it
98 contour 2.0
Posts: 1,609 |
I got a set of stock rear springs (one has 500 miles the other has 0), PM me if you want em, Ill give ya a good price
1998.5 SVT contour #5979 3L ![](/ubbthreads/images/graemlins/smile.gif)
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 191 |
anyone know if i'm going to need struts too? and what would ford charge?
98 contour 2.0
CEG road warrior
CEG road warrior
Posts: 17,248 |
What exactly does the car feel like? This will tell us if it is the spring or strut that is worn.
If you are going to replace one....replace the opposite side.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 191 |
when driving, getting out of the car, going over a bump, pushing down on the back the drivers side it clunks. it makes a loud noise. it feels to me as if the spring is cracked but i really couldnt see anything.
98 contour 2.0
Posts: 3,065 |
Clunking is usually a sign of something loose. Look around at the more simple options then going straight to R&R.
Posts: 191 |
I really can't tell anything, everything looks all right. The spring looks nice and solid. The symptoms are when braking i get a shake from that spring area, when going over bumps i get a dull clunk from the area.
98 contour 2.0
Posts: 191 |
98 contour 2.0
Posts: 508 |
Originally posted by volcomsk8a: anyone got another idea?
Inspect swaybar mounts, brackets and swaybarlink bushings and make sure the links r good and bolts r to correct TQ.
Also have someone else bouce the car, use papertowel roll on one ear and see if you can pinpoint the direction of noise. Even a mechanics stethoscope using just the tube can give you and idea how high or low in the suspension to start checking.
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
Posts: 191 |
well im still trying to pinpoint it but the sound sounds like its coming from the bottom of the spring where it goes into the cup, anyone ever deal with this problem
98 contour 2.0
Posts: 1,505 |
Originally posted by jd2-98s: Originally posted by volcomsk8a: anyone got another idea?
Thats what i was gonna say but you beat me to it. tThats not a bad idea.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 410 |
The last coil in the cup could be cracked. If you're replacing springs, do the struts as well. I put Monroe Sense-atracs on mine and new springs. Struts were $90 each. Coils were $75 each.
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
