Posts: 19 |
I want to no is it possible if I change the transmission and everything if I could take the 4 cylinder out of my Contour SE and repalce it with the SVT engine
Posts: 536 |
first off the svt engine is a v6 not a v8. now to answer your question. yes you could theoretically do it however you would need the engine, trans, wiring harness, pcm, subframe, radiator, and im sure there is alot of other stuff. thats just the big parts. it would be much easier to swap in the svt into a tour that already had a v6.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 5,345 |
Originally posted by striker2: .... it would be much easier to swap in the svt into a tour that already had a v6.
or just buy a SVT as it will probably end up being cheaper.
1996 V6 ATX 96K miles
Posts: 21,653 |
Much cheaper and easier and better and cooler.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,831 |
Originally posted by Kremithefrog: Much cheaper and easier and better and cooler.
Thats what i did! I wanted more power and performance, so i payed off the SE and went and got an SVT to compliment the SE.
A Contour is not just a car, it's an experience
99 T-Red SE Zetec ATX
Born April 16, 1999
98 E0 Silver Frost CSVT
#3175/3565
Born August 21st, 1997
Stored at P.R.T. for the winter
67 Mustang 289 project car
Posts: 7,117 |
Originally posted by Tony2005: Originally posted by striker2: .... it would be much easier to swap in the svt into a tour that already had a v6.
Can that! Just drop a 3L into the V-6 Contour & it will be better, faster, cheaper then the SVT swap.
Posts: 4,051 |
Originally posted by TourDeForce: Just drop a 3L into the V-6 Contour & it will be better, faster, cheaper then the SVT swap.
Huh?
What about the SVT UIM, LIM, TB, cams.....??
Posts: 2,116 |
you can squeeze the WHOLE 3.0L in there, no need for all that stuff if you don't want it.
95 SE MTX
svt exhaust
intake
deer killer
