Posts: 536 |
why not? my roommates GTP has hydrolic lifters and hes probably pushing close to 300hp if not more.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 498 |
Originally posted by Augi: Yes but the silvertop has Hydraulic lifters... the rest have mechanical right? I'm saying that the Hydraulic lifters can't handle more than a certain amount of power w/out changing them over to mechanical.
what do lifters have to do with it's ability to make power?
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 36 |
will you be using the stock TB or going for a 65mm one?
Posts: 495 |
In normal applications a bigger TB doesn't really do much. However, in the JRSC's a bigger TB does make big gains, so go with the biggest that fits.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 36 |
the throttle response is a lot better too
Posts: 1,224 |
Originally posted by d c: will you be using the stock TB or going for a 65mm one?
I already have a FC 65mm TB. It's just been sitting in a box. I keep forgetting to order a Focus throttle cable. BTW, I've also been toying with idea of using a 4.6L Mustang 70mm TB. It's the same one that Ford Racing uses on the FRPP intaks manifold. If you're gonna go big, why not REALLY big? ![](/ubbthreads/images/graemlins/grin.gif)
Originally posted by pre98zetec: what do lifters have to do with it's ability to make power?
I'm wondering that too. If anything, the boost will help push the valves open. I'm not going over the stock rev limiter either. Is this some old school V8 myth?
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 2,483 |
BP
The down side to hydraulic lifters;
Hydraulic lifters have a greater chance of floating at high RPM's and under high power applications ("valve floating"). The chances of floating goes up with wear on the lifters. this means that you have to back off the power a litle bit at high RPM's. Shouldn't be pushing the Zetec past 7K RPMs much anyway, so it shouldn't be a problem.
I'd suggest solid lifters if you're going big power and/or high RPM's.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 495 |
I wouldn't even push 7K rpms boosted. It's not just the valvetrain, it's the Rods. The stresses on stock rods, under boost, are approximately 30% more at 3000rpms, even with double the HP. At 6000rpms, though, the stress are multipled so it's not double the stress it's like tripled or more.
That's why I like turbo's cause you get all the boost down low, in my setup anyway, where the rods can handle the stress easier, but the JRSC only gives full boost up high where the stresses are much higher. On the upside, I hear it can be easier to tune a SC since the main power is in the upper RPMs so timing and fuel is easier to dial in right.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Meh.....hit 7000-7500 rpms a lot when I had my car.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 495 |
Yeah, but you really didn't have any power.
