Posts: 1,190 |
2001 is an earlier bolt style? 99+ for some reason they were not the same for mine....
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 5,810 |
No later, they use the 8mm bolts. My 99 used 8mm bolts as well but the 98's seem to have been a crossover year and had 10mm or 8mm bolts. My 98 Taurus block used 10mm bolts so to make it fit I drilled/tapped the 99 contour motor mount to fit the 10mm bolts and problem was solved.
On the '01 escape it used an identical mount as the 99contour mount I had, both in bolt size, shape, and functionality. So consider it another source of a motor mount if you wish.
See My Mods
Posts: 1,190 |
thanks for the explanation...i was confused...lol
#702 of 2150
Posts: 1,190 |
if anone wants to get an idea of what i went throught today take a look...
check these out...not your typical motor....all work was done by me...all in one day...
#702 of 2150
Posts: 21,197 |
Umm why are you asking about installing with the heads on if one is off?
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,190 |
cause i said fug it and tore the motor apart!
#702 of 2150
Posts: 21,197 |
Okaaaaay. A little grinding would have saved $ on a new gasket, TTY bolts, removing the cams, redoing the timing if that was done. 40 minutes of grinding > removing a head.
-'96 SE MTX 3L
Posts: 1,190 |
Originally posted by Todd aRRRRRRRRR.: Okaaaaay. A little grinding would have saved $ on a new gasket, TTY bolts, removing the cams, redoing the timing if that was done.
gasket was fine..the engine has never been run..ARP head studs....did the work my self so it didn't cost me a thing..
diamond pistons and gasket
the most beutiful friggen cylinders and pistons i have ever seen
#702 of 2150
Posts: 10,015 |
Originally posted by svtProdigy: Originally posted by Todd aRRRRRRRRR.: Okaaaaay. A little grinding would have saved $ on a new gasket, TTY bolts, removing the cams, redoing the timing if that was done.
That was a bonehead move!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
From I've been told it doesn't matter. The gaskets are coated and have been compressed. Reuse is not recommended.
-'96 SE MTX 3L
