Ok,
First day I ever take the whole family in this ride and the A/C fails when I leave Grandma's house
So I check and the compressor is not cycling at all. So I think I can rule out a leak in the system. (I had one repaired last year and the compressor cycles on and off quickly.)
So I suspect one of the switches is not working properly.
With the engine running, and the A/C in the ON position, I do NOT have a 12V at either terminal on the compressor clutch. On one terminal I do have a ground (tested with the engine and A/C off).
I then probed the wires that attach to the switch on the dryer (I think that is what it is, the cylinder near the firewall.) And one of the wires had +12V. I then checked a switch closer to the compressor. I don't know if this is the high pressure switch or not, but it goes to one of the lines that is near that little A/C radiator up front.
(Don't you just love my terminology?)
I did have +12V there too. I haven't checked the switches yet to see if they are open or closed, but I suspect at least one of them to be closed.
Now my questions.
1. Am I on the right track? I think so, since I'm looking to engage the compressor.
2. Other than checking these pressure switches, are there any other switches that I've missed.
3. Am I justified to suspect the second switch mentioned (the one NOT on the dryer.) It seems that the switches would progress from the power relay on the firewall, to the compressor.
I believe from the pretty lame diagram in the Haynes repair manual I have, that I have a good relay and good power, as I expect these switches to be part of the path between the +12V source and the compressor clutch.
I don't expect to actually replace one of these switches myself, but would like to have an idea what it is when I take it to my mechanic and describe what I've learned so far.
Thanks for any all suggestions. Suggestions of where to find better wiring diagrams, especially on line will greatly be appreciated.
TB
