Hey guys,
I have pretty much the same problem everyone else is having, rough idle, no pedal response off line, to the point where it just dies and dosen't react to gas pedal, stalls in morning if I dont rev it for first few minutes, check engine light is on..
So I brought it in to this shop that I know, cause I replaced the fuel filter and the spark plugs and wires and problem just came back. He hooked it up to the computer and thinks these problems are caused by the Throttle Position Sensor. I know the guy and he said I could do the work myself and save myself some money.
He said the TPS is measuring 1.7 volts and its supposed to be 3.4 volts (or something like that). My question is, does this make sense to you guys? It is not an expensive part, but I am tired of replacing things under the hood with no result. Bear in mind I havent cleaned the MAF before.. Could the voltage difference just be caused by the MAF or something? He said this was a common problem with Contours (Duh) and he thinks it is the TPS. Thanks for all the help.
-Dylan
